unconfigure vm-tracking vpp
unconfigure vm-tracking vpp vpp_name
Description
Removes the association of a policy or ACL rule to an LVPP.
Syntax Description
vpp_name Specifies the name of an existing LVPP.
Default
N/A.
Usage Guidelines
None.
The following command removes the configuration of LVPP vpp1:
# unconfigure vm-tracking vpp vpp1
This command was first available in ExtremeXOS 12.5.
Platform Availability
